Perfect Power maps for 22t?
sliverumble
Post by sliverumble »
Does anyone have maps for a legacy ss using the PP smt6? Just need a base map.
Thanks,
Grant
92 SS
-TD04
-3" dp/ turbo back w/HKS can
-wrx/legacy susp combo
-Tribeca Front Sway
-whiteline rear sway
-wrx front brakes
-sti lip
-ver.4 sti tranny w/rear diff
-wrx tmic
-mbc @14.5-15psi w/HKS FCD
-Apexi turbo timer
douglas vincent
Re: Perfect Power maps for 22t?
Post by douglas vincent »
A base map is a blank map that simply allows the PP6 to let the engine run. The base map somewhat depends upon the wiring of the PP6 (the global settings).....
Do you have the bypass plug? If the PP6 is wired correctly, then you can use the bypass plug and run the stock ECU, no PP6. This GENERALLY shows the PP6 has been wired in correctly.
Then, at this point, you can plug in the PP6, start the car and see if the global setting are correct. You would want ZEROs in all the PP6 maps and IF the global settings are correct for the wiring, then the car should run as stock.
Then you start fucking with it....
sliverumble
I do have access to a tuned LINK G4 map from an ej20g with td04. would i be able to transfer over info from that map and have it work on the pp smt6? Just a thought
92 SS
-TD04
-Tribeca Front Sway
-wrx front brakes
-sti lip
-wrx tmic
-Apexi turbo timer
gijonas
Post by gijonas »
lol!
