so my black 93 daily has rod knock after a night of cyclones
at the local wrecker here there is a ej22t and also a ej25d from a legacy gt
now my question is should i buy the 22t block for 135 or buy the 25d block and heads for 165?
i know the comp ratio is a lot higher so id keep the stock turbo and keep the boost low
has any one else run the 25d motor on 22t ecu?
rod knock, 22 block or 25d motor?
Re: rod knock, 22 block or 25d motor?
I would just put a EJ22T back in.
91 black SS 5 speed (Canadian).... Closed deck EJ20G, fully built, V5/6 sti ra drivetrain, haltech stand-alone
93 silver TW 5 speed... rebuilt 22T with 20G heads, wrx ra drivetrain, otherwise stock.
73 kazen red VW bus riviera camper
Yep, EJ22t. The 25D doesn't have a good reputation when turboed.
fiiiiiiiiiiiiiiiiine i pulled the 22 block today lol. 180$ later time to pull my motor now i guess
best part about the 22 block i got is it has 126km on it, thats only 78 292 miles
Indeed, given the option I would use that engine in any car. I have an EJ25D in my Outback and, while it's quite a good engine so far, I don't trust it like I did my 22T.
Legacy Central
