E85
Re: E85
I know there's been some that have done it, but the ones I've read of were on nowhere near stock builds. Search for E85 in the Google search, should bring up some stuff. AFAIK on our cars it requires a standalone.
Re: E85
Standalone ECU, 550cc at the minimum, larger fuel pump, and more boost...that is how I do it.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
Re: E85
I figured 550 would be too small. I've got the pump (walboro 340) and the stand alone (power fc). I've got a TD05 and I want to run 22psi, but at that CFM(about 535) I can't figure out what sized injectors to use. I've also heard you need to change plugs.
Re: E85
550cc are the minimum I was able to run. I believe they maxed out at 18psi on a vf39.
I would go 850-1000cc injectors. It's always better to run 70% duty then 90% duty on the injectors.
I think I run one step colder plugs.
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
