Bad turbo cause engine damage?
Something got in my intake and chewed up the cold side of the turbo blades. Should I start looking into replacing internal motor parts?
Re: Bad turbo cause engine damage?
That's not to bad... iv definitely seen worse. I only see the one "big" piece missing on the blade at the 7 o clock, that could have messed up your cylinder walls. As long as you caught that in time your probably fine. Did it make a lot of noise? Also depends on what was stuck in there and is now in your engine. Change your oil and report back what you find.
1990 NA 2.2 Open Light rally car
