crank trigger sensor assembly 2.2 vs 2.5
WRXish
Post by WRXish »
Is there any difference between a 91 2.2 and a 98 2.5 in the crank sensor and the trigger wheel for it? How much trouble is it to swap the 2.2 sensor setup onto the 2.5 or is that even necessary?
Re: crank trigger sensor assembly 2.2 vs 2.5
Same triggers
WRXish
Post by WRXish »
outstanding!!!!! thank you for that...
