The wife just said her gas pedal stuck a few times
icrman
Post by icrman »
Any one have that happen? Its a 93, is it a throttle cable going bad?
rallyak
Re: The wife just said her gas pedal stuck a few times
Post by rallyak »
I would suspect the cable, mine has been sticking for awhile now and have a replacement cable but haven't replaced it yet. But only sticks at idle. It will hang up and my rpm will be around 1200 but if I blip my throttle it will unstick.
Charles
icrman
Post by icrman »
I did some spray lube on the pivot points of the pedal and the throttle body and so far no complaints.
rallyak
Post by rallyak »
I've done that but didn't help, hope you have better results.
Charles
