Which IACV? HELP
WRXish
Which IACV? HELP
Post by WRXish » Sat Mar 18, 2017 2:58 pm
Engine is a 98 25d from an automatic car, running I hope soon in a 91 legacy l on obd1 electronics. I have both the correct IACV for the engine and one that matches the electronics in the car...which way do I go? Please help.
rallyak
Re: Which IACV? HELP
Post by rallyak » Sat Mar 18, 2017 4:41 pm
Match the one with your car if you have a 5 speed. If you have 4eats I believe that the IAC should be the same.
Charles
