»  BC-BF Legacy Discussion »  Engine
#1991 Legacy NA Timing Belt kit v. Turbo Timing Belt Kit
Custom Search
Login | Register
Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: 1991 Legacy NA Timing Belt kit v. Turbo Timing Belt Kit
PostPosted: Wed May 10, 2017 9:47 pm
I am wondering about the differences between these two kits. Will all of the components in an NA kit work except for the water pump on the SS? I picked up the NA kit on accident and am wondering if I can use all of the components and just pick up a proper water pump. I have seen posts that point towards this but nothing solid enough to convince me. Any help is appreciated!
If I missed an obvious thread please post the link as well.
Rusty 1991 EJ22T - VF28 - '07 wrx TMIC - MBC - Invidia DP - Walbro 255 SOLD
1992 Legacy SS 5mt, with some neat stuff on it
Profile  Offline
 Post subject: Re: 1991 Legacy NA Timing Belt kit v. Turbo Timing Belt Kit
PostPosted: Thu May 11, 2017 12:08 am
Found it. Just needed a little more patience.
Timing belt pulleys, cam shaft sprockets/gears, and tensioner are the same between stock turbo and NA engines from '89-94 (and some newer); water pump is specific to the ’92-94 turbo, and the ’91 turbo also has an extra port on the water pump to feed the oil cooler only on the ’91 EJ22T. The ’91 should be the same part number as the USDM WRX.
I pulled the info from this link:
viewtopic.php?f=5&t=45769
Profile  Offline
PostPosted: Thu May 11, 2017 3:16 am
Yes, that is correct.
2005 Legacy GT Limited Wagon 5-Speed. Stock-ish ;)
Profile  Offline
Who is online
Users browsing this forum: Bing [Bot] and 3 guests
Panel
Search for:
Jump to:
 cron
Dizayn Ercan Koc
