»  BC-BF Legacy Discussion »  Engine
#Ej22E to EJ20G Swap
Custom Search
Login | Register
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: Ej22E to EJ20G Swap
PostPosted: Thu Jun 08, 2017 3:44 am
Hey guys, I have a 92 wagon with the ej22e, 5mt and I think its time for a new engine.. I have been doing some research about possible swaps. I see a lot of ej22t to ej20g swap info and "guides," but I am not familiar with the legacy ss. Is the swap similar or should I go with a different rout? Thanks for any advice in advance :D
Profile  Offline
 Post subject: Re: Ej22E to EJ20G Swap
PostPosted: Mon Jun 12, 2017 5:18 pm
Welcome to the BBS.
The swap should be similar. There will be little differences and things that need to be done, but I can't think of any show stoppers. The main difference will be the ignition and having to rewire things for coil on plug vs. wasted spark.
1997 Impreza OBS
Profile  Offline
PostPosted: Fri Jun 16, 2017 4:46 pm
Okay great! That shouldn't be too difficult. Thank you for the info. If I do find myself stuck somewhere I know where to ask.
Profile  Offline
PostPosted: Fri Jun 16, 2017 9:34 pm
Dont forget to acquire the turbo related sensors! (map, pressure exchange etc). If you plan on putting a different turbo specific transmission in, you will more than likely also have to go to a hydraulically actuated clutch. Doing this same thing as we speak, just a 22t instead of a 20g. Good luck!!
White 1993 L Wagon AWD 5MT-Suspension upgrades Daily/Backroads Slayer 361xxx miles
White 1991 L sedan AWD 5MT-(Robtune 550 DOHC Ej22t swap coming together) 187xxx miles
Profile  Offline
PostPosted: Sun Jun 18, 2017 10:10 pm
Don't forget the front crossmember.
Sent from my SM-N900V using Tapatalk
Profile  Offline
PostPosted: Mon Jun 19, 2017 4:37 am
Winestone Cowboy
Don't forget the turbo lol
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
