»  BC-BF Legacy Discussion »  Engine
#White smoke at higher RPM...advice please?
Custom Search
Login | Register
Post new topic Reply to topic  [ 16 posts ]
Author Message
 Post subject: White smoke at higher RPM...advice please?
PostPosted: Tue Aug 29, 2017 9:03 pm
So I have a 91 Subaru Legacy Wagon LS and it runs great. Doesn't feel like any lower loss trans is fine. So the white smoke isn't a lot and I already know I have a blown Headgasket. But my question is should I just replace the engine altogether, just do the Headgaskets and maybe new heads? I would hate to see this poor thing end up in a car graveyard as these guys are getting rarer by the day. Any input helps guys thanks! Image
Sent from my Z983 using Tapatalk
Profile  Offline
 Post subject: Re: White smoke at higher RPM...advice please?
PostPosted: Wed Aug 30, 2017 12:36 am
If you can do the work, I'd say replace the head gaskets and have the heads inspected for warpage. If you have to pay someone, you'll come out ahead buying a used engine and replacing all consumables on it.
Profile  Offline
PostPosted: Wed Aug 30, 2017 12:52 am
Okay. I might look into replacing the engine altogether. It has 230k now and has original engine and I'm sure the Headgaskets sere only changed once before hand. Do you maybe know of any high compression engines that are around so I could a little more power out of it? Or should I just stick to the stock tank 2.2
Profile  Offline
PostPosted: Wed Aug 30, 2017 12:53 am
And if I buy a new engine can it be any 2.2? Or better yet a 2.5 with good heads if I can find one?
Profile  Offline
PostPosted: Wed Aug 30, 2017 1:28 am
Any pre 1999 ej22 will work, you put your current intake manifold and sensors on, and away you go. An ej25 swap is an epic ordeal, a couple of people have done it if you want to search though.
Profile  Offline
PostPosted: Wed Aug 30, 2017 2:10 am
Might as well turbo it before you do a 2.5 swap. Lol
Had more Legacy's than I know what to with...
Current: 92' SS
Profile  Offline
PostPosted: Wed Aug 30, 2017 2:33 am
Lol and watch the engine go boom after I know my Headgaskets are bad. I'll do that when I have another ej22 in my hands first
Profile  Offline
PostPosted: Wed Aug 30, 2017 2:40 am
If I just do the Headgaskets which kit should I buy? And when I do this should I go ahead and replace all cylinder heads just because I know it's leaking? It already has new spark plugs timing belt filter all done by myself and kept up well on oil. But I don't have an engine hoist to pull the engine out myself...unless you can do it while it's in there? But I doubt it?
Profile  Offline
PostPosted: Wed Aug 30, 2017 6:03 pm
If you're just doing head gaskets, and want the best, then it's gotta be OEM. I used felpro on my old ej22 NA years ago and it's still ticking. You can do the ej22e head gaskets in that engine bay without pulling the engine. Its significantly harder than if you pull the engine. But I've done it.
99% chance you won't need new heads, just have a machine shop inspect them
Profile  Offline
PostPosted: Fri Sep 01, 2017 11:26 pm
Okay. If the job of changing them is easy enough than I just might do it myself. Is there anything major to watch out for when doing it like little pieces that spring out or might need to be scrubbed clean while I'm in there? Or anything else that's worth changing out while it's all open? Think I might try it myself to save a mechanics bill
Profile  Offline
PostPosted: Tue Sep 05, 2017 6:05 pm
So just how much of a mess am I getting myself into? Everything looks pretty straight forward as taking everything off goes. Just don't mix anything up. Can I get it done in a couple hours? And what should I clean while it's all open? Any more tips anyone? This will be my first ej22 teardown and she's my daily so I don't want to completely mess something up...
Profile  Offline
PostPosted: Tue Sep 05, 2017 8:49 pm
You gotta budget yourself a weekend at least. Out of the car I could see it taking a couple hours. Remember, you don't know if your head's are warped or not. If they need machining, that could take a few days, or a week+ if the shop can't get to it right away.
Just be methodical and replace anything consumable that you touch.
Profile  Offline
PostPosted: Tue Sep 05, 2017 8:51 pm
Try to arrange a car you can borrow short term till it's done.
Profile  Offline
PostPosted: Tue Sep 05, 2017 9:12 pm
It has newer spark plugs up from January, and I also did the timing belt at the same time myself which was a bitch to figure out the teeth at first. I have to take the timing belt back off again don't I? My girl friend has an extra car I can use for the couple days if I don't get it done on the weekend. And if my heads are warped wouldn't it be better to just buy new heads and replace them? I'll check up on the injectors too but I think I might just want to replace those anyway, Eventhough there never seems to be a problem with fuel delivery. What would be the most ideal to replace while it's open? I might as well get it all done at once and not do it again 6 months later. So the Headgaskets, possibly heads and maybe injectors?
Profile  Offline
PostPosted: Tue Sep 05, 2017 9:38 pm
You can get rebuilt heads if you want, but the old NA engines don't tend to crack or warp. Matter of fact it's almost unheard of, but it would be unwise to not have em checked. If you're concerned about the injectors just have them flow tested and cleaned and replace only the ones that fail.
You're going to want the buy a full upper gasket set for the engine. Replace every gasket and seal that comes with it as necessary. I wouldn't bother with the throttle body gasket, unless you remove it for some reason. You won't for a HG job. You mentioned timing belt replacement, did you do the water pump and belt rollers?
To do the HGs, you'll be unbolting the exhaust manifold, removing the full intake manifold, timing belt, power steering pump and ac pump. There isn't enough room to the frame rail to remove all the head bolts so you'll have to pull the heads with some left in. I would estimate putting everything back together to be about 20 times harder than doing the timing. But perhaps that's because I did it outside in the snow ha ha.
Profile  Offline
PostPosted: Tue Sep 05, 2017 11:25 pm
I did do the timing belt but it was at bad timing lol. The cars belt jumped as I was getting on the freeway so I towed it home and worked all night until I got the thing to start. All I did is buy a new belt. I didn't do the water pump or the rollers...i should have but money was tight then. I won't be doing mine in the snow haha yet. I gotta get it done though. So it definitely sounds like a couple day job to me. Would be a great learning experience. I love these cars
Profile  Offline
Who is online
Users browsing this forum: No registered users and 3 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
