legacycentral bbs
https://bbs.legacycentral.org/
NEED HELP! Swapping 22T to 20G, Exhaust Cam Gear Lip Damaged
https://bbs.legacycentral.org/viewtopic.php?f=5&t=56259
Author:  scoobydoo94turbo [ Sun Feb 11, 2018 4:16 am ]
Post subject:  NEED HELP! Swapping 22T to 20G, Exhaust Cam Gear Lip Damaged
Swapping out my EJ22T from my 93 Legacy Turbo Sedan to a 1995 EJ20G WRX STI engine. I removed the timing belt cover to inspect and found the driver side exhaust cam is missing a small chunk on the lip causing the timing belt to wear on the outer edge, heavy belt wear present as well as scoring on idler pulley, also noticed timing belt tensioner has been upgraded to new style with extra small pulley. Is this the cause of the cam gear failure? See detailed pictures
Author:  jamal [ Fri Feb 16, 2018 11:20 pm ]
Post subject:  Re: NEED HELP! Swapping 22T to 20G, Exhaust Cam Gear Lip Dam
What's your question?
No the tensioner is not causing any issues.
Yes you need to replace that cam gear. Looks the same as a Legacy GT 25d part.
Page 1 of 1 All times are UTC [ DST ]
http://www.phpbb.com/
