Injectors ?
icrman
Injectors ?
Post by icrman »
Does anyone know if there is a difference between EJ22 and EJ20 injectors?
The holes look the same, the EJ20 does not have the little cage looking thing at the end. There was a 2 instead of a 1 at the end of one of the numbers on the top. ????
Also where is a good inexpensive place to get the o rings at?
Re: Injectors ?
I would think that yes there probably is a difference between injectors. There are differences in injectors just between the first gen 2.2 legacy.
As for O-rings, you could try a fuel injection cleaning place to see if they have new injectors.
