ECU advise: apexi on 22t?
Posted: Fri Dec 07, 2018 8:51 pm
Hi
I need some advice on my project. I am building an EJ22T with forged internals EJ25D heads, 550cc injectors and a td05-16g.
I have a 4 plug Apexi fc power commander ecu for en EJ20G will it be able to work on my EJ22 i am maninly thinking about ignition now that the 22T uses coil pack and the 20G uses coil on plugs.
Thanks in advance.
Thanks in advance.
