The Torque Output of an EJ22T?
How is it that our stock EJ22T powered Legacys put out 181 ft/lbs of torque? 20ft/lbs of torque more than HP. This is very unusual for an engine? Is it the turbo? Also at what RPM is the torque at 181ft/lbs.
Thanks,
Mark
Thanks,
Mark
The motor has more displacement then say the WRX.....so the amount of torque is going to be more......which is why this motor is such a good platform for monster motors.....
Turbo engines nearly always have more torque than HP.
That 181lb/ft is at 2,800rpm.
Legacy Central
Because our turbo's are very small, and they designed the turbo to spool quickly for good low end power.
-aaron
EDIT: hey morgie, my mistake, it is not 2800 rpm. mine is at stock boost level (8.7psi) and a k&n filter w/ snorkus removed. mine is spooled by about 3300.
-aaron
92 Legacy Turbo \ 5MT \ Silver
I'm just going by the Subaru specs, so don't shoot the messenger
Legacy Central
Turbos almost always have big torque. That just keeps on going, flat enough to build a house on. You might not get full boost untill 3000 rpm but even at 0 psi (no vac) the engine doesn't have to suck air. That makes a big difference. Turbos also don't need to run a big cam. You get a mild cam that makes good torque down low and make up for it going flat on top end with boost.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
93 Sport Sedan, 5mt
