05 STI lateral Links
snowjob
Post by snowjob »
I've got the chance to pick up a set of 05 sti lateral links and trailing links for 99 shipped to my house, will these fit? I know I may have to change my endlinks for the swaybar, but would they be useful, anyone tried, thanks
Frazer
04 modified XT
99 LGT Limited
BAC5.2
Post by BAC5.2 »
No. The STi has a wider track than we do, so the lateral links are wider. You could get them to work, but they would make your rear end all wide tracked and ghetto looking. The STi also has different hubs, so I don't know that they will work.
The GC rear arms should be the same length though, if you can score a set of those.
Chrisg03
Re: 05 STI lateral Links
Post by Chrisg03 »
i know this is an old thread but just how accurate is this ? when i was test fitting i saw a difference of about 1/4 to 1/2 an inch does it make such a difference?
Always open to learn
rallyak
Post by rallyak »
Can you say "negative camber", 1/4-1/2 is a lot when it comes to the alignment.
Charles
Chrisg03
Post by Chrisg03 »
Really? okay it does make sense ..but would it have any adverse effects? i mean i seriously dont want my car to look "cambered" but my links are dead rubber is completely broken off
Yes it will have adverse affects on how the car handles, drives, etc.
Chrisg03
Post by Chrisg03 »
okay thank you guys for your help guess imma have to hit the yard real quick for some BG links
