rear lateral/control arm bushes
MY92
Post by MY92 »
does anyone have the sti part # for these items? or recommend a good replacement for blown out oem rubber bushes.
cheers
John
http://www.cardomain.com/ride/560635
Subaru for Life
Re: rear lateral/control arm bushes
Post by Subaru for Life »
This is where I got mine from, probably one of the cheapest around. No need for the part number, it's already sorted out for ya.
Pye
MY92 wrote:does anyone have the sti part # for these items? or recommend a good replacement for blown out oem rubber bushes.
cheers
MY92
Post by MY92 »
Where exactly?
John
Subaru for Life
Sorry, was at work and got busy :-D
If you need more info. just shoot an email to Jamie (Parts manager), or give her a call. She's very helpful.
https://www.subarugenuineparts.com/adva ... 3ff47efa52
The SuperPro rear lateral link set is cheaper than those STi bushings. $89.95 for the set. http://www.boxer4racing.com/
scottzg
Post by scottzg »
93forestpearl wrote:The SuperPro rear lateral link set is cheaper than those STi bushings. $89.95 for the set. http://www.boxer4racing.com/
but they're polyurethane :(
MY92
Post by MY92 »
And?
John
THAWA
Post by THAWA »
Poly sucks.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
And why does polyurathane "suck"?
There may be more NVH, but poly is stiffer and more durable. Why the hate?
206er
Post by 206er »
squeaks?
I'm sure if you would price factory bushings, the poly ones would be as cheap or cheaper.
me, I want to machine some bushings out of delrin. :twisted:
MY92
Post by MY92 »
Other than 'sucks' as a reason, does anyone else have a view on poly bushes in the control arms?
Josh? you out there.
John
THAWA
Post by THAWA »
Poly is much less durable than rubber. Depending on the place of the bushing and how it moves, a poly one will destroy itself on the inner race with normal use. Radial movement is horrible for poly bushings.
Also, you can definately make a rubber bushing that has a higher durometer than most poly.
Spherical would be the way to go I say.
MY92
Post by MY92 »
Good come back :)
I might look into the STi bushings then.
John
THAWA wrote:Poly is much less durable than rubber. Depending on the place of the bushing and how it moves, a poly one will destroy itself on the inner race with normal use. Radial movement is horrible for poly bushings.
Is that your opinion that poly is less durable? I've never heard complaints like that againt polyurathane. The SuperPro bushings have a texture on the inside that holds the lube agaist the pin. A common mistake is people don't use enough of the speacial lube, or use something petrolium based. That, of course, will destroy the bushing.
THAWA
Post by THAWA »
It's a fact.
Ok, its a fact, but I'm just wondering who out there has had problems, and under what application(s).
I don't have the info on the lateral links because I used the whiteline adj. links that come with poly bushings.
scottzg
Post by scottzg »
ive personally seen a set of PU bushings on a vw that were so tight the suspension couldnt go to full droop as fast as i could jack it up, and then a 25k later they were so loose that you could feel the slop while driving the car. I imagine constant lube maintenance would make them last longer(i dont have a clue how those were maintained beyond that the original lube was done correctly), but why bother when you can get a more appropriate part for the application?
After doing a little research, ahem, I found that poly bushings are one of those things that will work great, but require regular maintenence. If they are squeaking, that means the pin is sliding against the poly without lube. That is when they start to destroy themselves. Polyurathane is sticky (think rollerblade wheels) and without plenty of lubrication, will get torn apart.
You gotta give a little to get a little.
MY92
Post by MY92 »
So PU only for serious cars then.
John
THAWA
Post by THAWA »
PU only for people that have time to constantly lube.
Spherical for serious cars.
I really think the lube thing with PU is over exagerated. I've got poly bushings on my lateral links & front & rear anti-sway bars and haven't messed with them at all....they don't squeak, and I haven't had any issues.
I think I regreased the rear anti-sway when I took everything apart for the AWD swap....but that'd just be stupid of me not to.....
THAWA
Post by THAWA »
It's not overexagerated, it just depends on where the bushing is used, and how forces are being applied to it.
The VW thing isn't uncommon because of the placement of the bushing and where the forces are being applied.
MY92
Post by MY92 »
I got a bargin on some PU bushes yesterday for the control arms and the trailing arms.
Will report on them once the're in.
John
scottzg
Post by scottzg »
THAWA wrote:The VW thing isn't uncommon because of the placement of the bushing and where the forces are being applied.
serious, the bushings on the torsion beam were HAMMERED. Must be because they influence the camber in the rear. The front was what made the car hard to drive though, because the steering was all sloppy and the car was kinda darty.
pu is fine where it isn't supposed to move, like on the steering rack or on the bottoms of droplinks- i have PU there myself.
as for over-exaggerated, although the 'net tends to do that, i only am speaking from experience. good luck!
