I want to get STI top mounts as soon as possible. Everyone I have contacted seems not to be able to get them.
Worst case, can someone tell me part numbers for rear strut tops that will work with the standard size rear srpings? Im assuming any 92-94 4wd legacy and any 93+ 4wd impreza mounts would work.
I NEED REAR MOUNTS. If someone has used items Id be glad to grab them.
I want STI tops RIGHT NOW, anyone have alternate source?
Do you want them for the larger sized rear springs? or the tapered ones?
The larger ones. If I dont find them Im going to visit my local dealership who usually charges 150-200% more than subaruparts and get the standard legacy parts
Dale at teagues told me this in email:
Also does anyone have the measurement of the rear gc8 springs and/or the standard legacy springs worldwide (not soa cone shaped from 90-91)
I can measure the legacy ones myself if needed.
Can anyone confirm this? If so does anyone know a source for these parts? At least the rears?The Front are the same as the 93-2003 WRX and the rear should be the same as the Impreza 93-2001.
ciper you should be fine with the standard top mounts that fit any impreza. The fronts have not changed at all.....so you could get some for a 90 legacy or 2000 RS. The wider rears shouldn't have changed at all either, so just get a set from a late model impreza.....minus the wrx.
