»  BC-BF Legacy Discussion »  Suspension
#STi/WRX Suspension Swap on 94 Legacy
Custom Search
Login | Register
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: STi/WRX Suspension Swap on 94 Legacy
PostPosted: Mon Oct 17, 2016 6:37 am
I have a 94 Legacy L AWD wagon. I am looking to upgrade the suspension.
What year STi/WRX struts and springs can I bolt directly on? What would it take to swap 2013 STi struts and springs?
I know nothing about my current suspension dimensions or even the intricate parts on any given suspension setup. I run 195/65 r15 tires.
This novice thanks you for your help.
Profile  Offline
 Post subject: Re: STi/WRX Suspension Swap on 94 Legacy
PostPosted: Mon Oct 17, 2016 7:28 am
Hi and welcome! Check out the Suspension Compilation Sticky thread, the first posting in this section.
Profile  Online
PostPosted: Mon Oct 17, 2016 10:23 pm
Vendor
Vendor
Those will not work at all. The front lower mounts on the sti are larger, the front top mounts are different, and the rear of the 08+ impreza has a completely different suspension design.
Most 02-07 impreza parts will sort of work but that is all getting pretty old if you are finding used parts and does not exactly fit anyway.
My suggestion would be to buy some new KYB struts meant for the 92-94 legacy. That's about $300 in parts. If you are looking for better performance I could probably come up with something, depends on what you are trying to do and how much you want to spend.
Profile  Offline
PostPosted: Tue Jan 16, 2018 2:52 pm
Yesterday I put my old struts from my 02' wrx onto the '90 Legacy Sedan. Just the fronts, it's what I had sitting around. Only think I had to do as far as modifications was the holder for the brake lines are different.
Profile  Offline
Who is online
Users browsing this forum: No registered users and 2 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
