»  BC-BF Legacy Discussion »  Suspension
#Coilovers for a 93 Turbo Wagon
Custom Search
Login | Register
Post new topic Reply to topic  [ 7 posts ]
Author Message
 Post subject: Coilovers for a 93 Turbo Wagon
PostPosted: Wed Apr 12, 2017 9:24 pm
Does anybody have any advice on good coilovers for my 93 Turbo touring Wagon? I'm new to Subarus so I'm not sure what all is interchangeable. I'm looking for something that doesn't take to much customization
Profile  Offline
 Post subject: Re: Coilovers for a 93 Turbo Wagon
PostPosted: Thu Apr 13, 2017 2:00 pm
There's cheap and rides like crap, and won't last very long. Or Very expensive with decent/good longevity and good ride quality.
Before you post in a section, make sure you are reading the "sticky notes" with threads of note. In the suspension section it's called "Suspension Sticky Compilation Thread."
Jamal and others have gone over what fits. Check out his blanket Suspension recommendations in the sticky. He is talking about struts and springs for the most part, but mentions one or two coilovers around the $1000-1500 range that don't break the bank but do ride well.
Basically if that's more than you want to spend, then you are stuck with the BC or Megan racing ones, or other cheepo eBay Chinese ones.
1992 Legacy SS 5mt, reasonably modified ;)
Profile  Offline
PostPosted: Thu Apr 13, 2017 8:11 pm
megan* ;)
Kris
'91 Mica White SS- "Gertrude"- R.I.P.
'88 White RX Turbo sedan- "Astrid"- SOLD
'91 Black SS- "Skaoi" - FOR SALE
'93 Silver Turbo Wagon- "Silver Fox"
'91 Black Camry Alltrac
Profile  Offline
PostPosted: Thu Apr 13, 2017 8:49 pm
Wut?
Profile  Offline
PostPosted: Fri Apr 14, 2017 4:23 am
Vendor
Vendor
Well, megan is not very good. Neither are stance, bc racing, raceland, k-sport etc, etc. Plenty of people use it, people like it, but I won't touch it. You want help and advice about that stuff, you are on your own.
I do have a thread that mike mentioned, but it is a bit out of date and some of the stuff in there is no longer available. However, I have recently gone over a few of the options still out there and have been meaning to start another thread about it.
Off the top of my head, KYB still has the AGX, and there are a coiuple of GC impreza specific coilovers out there that are both not crap and still available. The ST coilovers for example, which are a budget version of th KW variant 1, cost less than 1000. There is no reason to buy a megan/bc/k-sport etc part instead of those
Also, I do have that vendor thing going on and do like to help out the 1st gen legacy guys.
peter@functionauto.com
Profile  Offline
PostPosted: Fri Apr 14, 2017 8:14 am
Winestone Cowboy
I Have a set of Tein street coilovers, for 02-ish wrx, and am looking for a different spring, to try and "stiffing" the car a little bit. Do u know if they or someone else make a diff spring for the frt?
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 450k miles and climbing
Profile  Offline
PostPosted: Fri Apr 14, 2017 4:58 pm
Vendor
Vendor
Think they use 70mm ID springs. Eibach has a variety of rates and lengths. Do you know what the current spring rates are front and rear? I would guess 200 or 225mm long and probably 7k front 5k rear.
Going stiffer in the front without changing the rear would not be good for handling. But you could go up to 8k and put the 7k fronts on the rear. That would be stiffer, improve balance, and not be too much for the dampers. New, the springs are about $80 a piece.
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
