2001 rs struts
heyitzdinny
2001 rs struts
Post by heyitzdinny »
found a good deal on kyb struts for a 2000 rs. would this fit my 1991 n/a legacy ? can i reuse the springs and tophats with the kyb?
thanks
1991 N/a legacy
2003 subaru baja
2007 subaru sti -Maxwell power
Re: 2001 rs struts
Are they new or newer? I wouldn't bother with them if they are the original struts to that car, as my 2000 RS struts were quite worn after 14 years when I bought it.
If they are fresher, then yes I recommend them, and they do work with your springs and top hats
*Unless you have a FWD legacy, then I'm not certain if the rears will fit.
heyitzdinny
Re: 2001 rs struts
mike-tracy wrote:Are they new or newer? I wouldn't bother with them if they are the original struts to that car, as my 2000 RS struts were quite worn after 14 years when I bought it.
Awesome, i believe they are the newer one. thanks !!!!
1991 N/a legacy
2003 subaru baja
