»  BC-BF Legacy Discussion »  Drivetrain
#93 na to 5spd swap
Custom Search
Login | Register
Post new topic Reply to topic  [ 8 posts ]
Author Message
 Post subject: 93 na to 5spd swap
PostPosted: Sat Apr 15, 2017 9:06 am
Im well underway swappin in a 5spd jdm wrx trans...ive got everything but a starter. What works? Any 5 spd starter? Using a 02 wrx flywheel. And also. I never thought of speedo cable. Will my new auto cable work?
Profile  Offline
 Post subject: Re: 93 na to 5spd swap
PostPosted: Tue Apr 18, 2017 6:08 pm
What year is the trans from?
I used my auto cable. Depending on the year you may need to remove the speed sensor if it has one and get the MT speedo cable base piece so you can use the cable speedo.
1997 Impreza OBS
Profile  Offline
PostPosted: Fri Apr 21, 2017 8:11 am
Sensor removed. Auto speedo mechanical adapter screwed right in its place. Just hoping cable length isnt an issue. Its about 10" further back than auto speedo hole location. Tranny is a 96 jdm wrx close ratio
Profile  Offline
PostPosted: Fri Apr 21, 2017 5:57 pm
You probably will need the MT speedo cable adapter. It's p/n: 37410AA061
Kimo has a picture of it in his build thread.
viewtopic.php?f=25&t=40398&p=336165&hilit=37410aa061#p336165
1997 Impreza OBS
Profile  Offline
PostPosted: Sat Apr 22, 2017 3:59 pm
Any 5mt starter should work for your trans.
Profile  Offline
PostPosted: Sun Apr 30, 2017 10:55 am
Auto cable just reached with the auto adapter. 06 sti starter is a go. Pedal swap was an ordeal with the automatic push button heater box.. a harness sheethed in thick nylon conduit placed where 5sp pedals bolt up made that fun.. i followed a write up and built a patch harness from the neutral and reverse switch on the 5 spd tranny to the auto wiring. But im told now the ecu will see neutral every shift and really mess with things. Looking for proper neutral input. My friend suggested wiring direct to ecu wiring . Thoughts?
Profile  Offline
PostPosted: Mon May 01, 2017 5:21 pm
Have you read over my AWD & 5spd swap to know how to deal with the electrical/wiring?
It's all there and will tell you how to deal with the neutral switch and other items.
www.surrealmirage.com/subaru/swap
1997 Impreza OBS
Profile  Offline
PostPosted: Tue May 02, 2017 3:34 am
if you made the adapter to plug in the tranny, then you should be good. i did the same thing to my wagon and the only other electrical thing i did was snip the wire that goes to the cluster gear indicator.
Kris
'91 Mica White SS- "Gertrude"- R.I.P.
'88 White RX Turbo sedan- "Astrid"- SOLD
'91 Black SS- "Skaoi" - SOLD
'93 Silver Turbo Wagon- "Silver Fox"
'91 Black Camry Alltrac
Profile  Offline
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
Panel
Search for:
Jump to:
 cron
Dizayn Ercan Koc
