»  BC-BF Legacy Discussion »  Drivetrain
#6mt swap into 93 SS
Custom Search
Login | Register
Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: 6mt swap into 93 SS
PostPosted: Sun Mar 03, 2019 7:33 pm
New to the group, although I've used this to gather information for years. My 5 speed quit on my 93SS last weekend and ive decided to go for the 6 speed swap. I'm eyeing a 2007 legacy GT spec B, with the EZ engine, 6mt. Its about $1000 cheaper than the STI 6mt, and lacks the DCCD. I can't find any concrete details about how or if it will bolt up. Will an EZ transmission bolt to an early EJ motor? Has anyone done this swap before? What problems will I run into?
91 legacy wagon (daily rally car)
93 legacy sport sedan (project)
Profile  Offline
 Post subject: Re: 6mt swap into 93 SS
PostPosted: Sun Mar 03, 2019 8:58 pm
From what I've read, it fits the same as the STI 6mt.
The STI dccd can't be retrofitted, but you can swap in a front LSD from rallyspec or other sources.
Downside to that particular Spec-B trans, and different from the USDM Spec-B 6mt, is it has a short top gear.
Profile  Offline
PostPosted: Sun Mar 10, 2019 10:32 pm
I did it. Bought a 6 speed for a EZ30r for 1100 with a warranty. It looks like everything will bolt up. Planning on using a 2004 wrx clutch and flywheel. I have to add a stud to the transmission for the starter to work and male-male 4th gen legacy front axles. My rear end and drive line both look like they will work as well. Just waiting on parts at this point.
Profile  Offline
Who is online
Users browsing this forum: No registered users and 2 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
