Automatic transmission swap to a manual transmission year 2004
thatsme87
Post by thatsme87 » Fri Feb 14, 2020 8:38 pm
I have a question on swapping transmissions. Ive been looking at swapping out my automatic transmission for a manual transmission in my 2004 Subaru legacy outback. It has a 2.5l sohc engine in it that's got a really bad rock knock and so i going to take the engine out and replace it, so i wad thinking when i do that i could change out tube transmission as well. Ive never done this before and i am a little worried about the problems i will encounter and if i have to change it the rear end as well? Or if i need to change out the computer for the engine and tube cam shaft pulleys? And if i would need to jumper any of the electrical pins for the transmission? Any info would be amazing.
Re: Automatic transmission swap to a manual transmission year 2004
Post by mike-tracy » Sat Feb 15, 2020 3:15 pm
Josh made a write-up on how to do the swap here:
viewtopic.php?t=18370
Mechanically the information should be about the same, but electronically you'll have to hit up a site like sl-i.net, which deals with newer legacys such as yours.
When you go through to Josh's write-up, instead of using 1990-1994 legacy parts (such as driveshaft, pedal set, etc) use those parts from a 3rd generation legacy instead.
Josh Colombo wrote:
Mon Jan 14, 2002 10:23 am
Wait....I'm confused now.
