how to remove rear axle stub???
i need to rebuilt my rear diff on a 1991 legacy with the lsd.
but i can't figure out how to remove the rear axle stub. i know on some car they have a little bolt that hold it but i cant see it
somebodu can help me on that ???
From the diff?
The axle is held onto the diff with a roll pin. The diff has male stubs attached to it, and the axle is held onto the stub with the pin.
Rio Red '91 Legacy SS
Look inside the male stub, there is a star head/8pt bolt that connects it to one of the pinion gears. As to what size this is or where the heck your going to find a deepwell that will fit in there im still looking myself. Let me know if you find something
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
91 SS AT
All I've seen are held in with a reverse torx head bolt. Are you sure it's not just covered in dirt and grease?
I've never been able to find the proper socket, but if it isn't too rusted a standard 1/4 drive 8mm will work if you pound it onto the head. An impact wrench is a BIG help here.
[size=75]-97 Legacy (ain't never gonna die)
-92 SVX (attention whore)
-86 Brat (more fun than the SVX)
-92 SVX Racer (lightest SVX)[/size]
Taking a quick look at my FSM, it looks like for the LSD, the stubs (spindles) are simply held in with circlips.
I looked, and yours is just like the one I took out of mine, and the hole is just a hole. Nothing in it. It mentions the spindle set bolt for non-LSD units......
So you just gripped the stubs somehow and pulled them out?
Did you put a rod or something through the spring pin holes to have something to hold onto?
Any special tools used, like a puller to remove the bearing races?
I need to get the axle stubs out without damaging them so I can remove the LSD from the diff housing.
