I had the often discussed speedometer cable drive that screws into the transmission fail on my car.
I got one from a parts car and installed/reinstalled it several times but can't get my speedometer to work.
Just wondering if anyone has had the speedometer drive gear fail that is inside the transmission, as I am beginning to think that's where my problem may be.
That said, I can not turn the gear with a screwdriver, which I think I should be able to do if the gear is stripped or broken.
Any thoughts/advice appreciated.
Thanks!
Les
1990 speedometer gear in 4EAT transmission
Try sticking the cable in a drill and spinning it to see if the speedo works. If it doesn't then you know you have an issue with the cable. I'd ensure that's working before you focus on the gear inside the transmission.
Thanks to you both for your suggestions.
Actually, I did connect a drill to the speedometer cable to be sure that the speedometer is working. I had removed the speedometer/cluster at the outset, thinking it was a problem there, cleaned and lubed the cable, but alas...
The speedometer works fine when I use a drill to spin the cable.
Like I said, it's weird, because when I insert a wide blade screwdriver into the gear in the transmission, I can twist it back and forth, maybe an 1/8 of a turn, which is what I would expect it to do, if it weren't stripped.
But I have taken the drive unit apart and reassembled multiple times, being certain that the wide tooth of the drive unit is engaged with the gear, and that the cable is in the square at the other end.
It's bizarre, but I am very suspicious that, when the drive unit seized and snapped, maybe the gear in the tranny was hurt.
However, I cannot pull that gear out with an up and twising motion, so perhaps it is held from inside the case.
I am also getting multiple flashes of the "power" light, when I start the car to road test it, which I suspect may be because the transmission needs the speedometer to function correctly?
I am by no means a Subaru expert!
Ciper,
Thank you for the suggestion!
I am going to do that, and I am embarrassed to admit that I did think of it, but somehow had the idea that I had to have all 4 wheels off the ground at the same time.
(Yes, this is my first AWD car...)
My recent history includes several warnings for speeding (though not in the Subaru) so I am concerned about not having a working speedometer.
That said, I may have to live w/o one if fixing the problem is going to require R & R of the tranny in February.
There is a small steel plug pressed into the side of the differential casing, which is directly in line with the speedometer gear, so I am wondering if, behind that plug, there might be a set screw to keep the gear from coming out of the top of the case.
First stop, as you suggest, is to look to be certain that the gear is not turning.
Thanks again!
Thanks again!
Let us know what you find. You are correct the ECU & TCU need a proper speedo signal to operate correctly.
The cooling fans will remain on, and the torque converter will not lock up.
So it's in your best interest to get the speedo fixed as soon as you can. I'm not sure about that plug and whether it allow access to the gear. Let us know what you find with that.
Re: 1990 speedometer gear in 4EAT transmission
I am having the exact same problem, what did you find out notnowles?
Welcome to the BBS Brennan.
My suggestion would be to pull the adapter off the transmission so all that is there is the piece that goes into the transmission. Then jack the car up and try rotating the tires to see if that piece moves. I don't believe the engine needs to be running, but if you get nothing turning by hand it may be a good idea to try it with the engine running and transmission in D. Make sure to jack the entire car off the ground.
