What transmission is this? (with number)
aaronllewellyn
Post by aaronllewellyn »
1990 legacy Ls AWD 4EAT auto (SS motor and many swapped 91 parts)
The number on mine is:
TZ102ZJ1AA -4R
the normal 91 legacy SS transmission number seems to be
TZ102ZA2AA-MH
What's in my car>? I cant find it anywhere on lookups, and it need to be replaced.
aaronllewellyn
Re: What transmission is this? (with number)
ok found in a forum post in ONE topic. seems to be from a 91
Using this decoder,
http://main.experiencetherave.com/subar ... decode.jpg
I'd say the
TZ102ZJ1AA-4R is from a 91 turbo (Just to note the 1 should indicate 1990, but since there isn't a 1990 MY turbo Legacy, the trans & car was likely made in 1990, but the car was a 1991 MY)
TZ102ZA2AA-MH is from a 91 non-turbo
Casper2be
Post by Casper2be »
I know this is a older post but TZ102ZA2AA-MH Transmission i put it into a 1993 subaru legacy 2.2 awd sedan automatic.... been in for years but now i want to change the click plates in the transfer case, the thing is when i look up it for either a 1991 or 1993 it shows four clutch plates to a set... and mine has five in it?
Do you know there are five in it because that's how many there was when you rebuilt it or are you going off the manual?
Based on what I see in the parts manual it list five plates so where are you looking that says four?
Go to page 254 of 1,265 that shows the diagram for the clutch plates. Page 253 item 1 & 2 show a quantity of five.
https://main.experiencetherave.com/suba ... og_-_FULL/
