driveshalf shaking
93FrostWhite
driveshalf shaking
Post by 93FrostWhite »
so when i turn in any direction and go like 3+mph the you can feel the driveshalf shaking. also if i turn the wheel at full lock it feels like the car is hard to move like its strainging. any i deas what this could be its a 93 legacy with a rebuild forester trans with a 3.90 center and rear diff
robertpaige
Re: driveshalf shaking
Post by robertpaige »
check the 4 bolts that connect the driveline to the rear diff. Mine were loose at one point. Lost 1 even.
93FrostWhite
I just went threw all 4 today and tighted them down and still nothing
lucas
Post by lucas »
check the carrier bearing, its the part of the drive shaft that splits and bolts to the body.
1993 legacy ss "Shela"
93FrostWhite
it looks beat what year drive shaft can i use?
Any 90-94 AT driveshaft will bolt in.
