93 legacy clutch question
trippywhitekid
Post by trippywhitekid »
i have the oem trans still but was wondering if this cluthc set up will work
https://www.rallysportdirect.com/fits/2 ... ent-clutch
trippywhitekid
Re: 93 legacy clutch question
this clutch is fora 2004 wrx with the 2.0 motor
Do you have a 1993 turbo or non turbo transmission?
trippywhitekid
i have a 93 turbo transmission
trippywhitekid
and is the clutch pull or push type? i have a friend saying its push but all i see is that they're pull types
The 1993 turbo transmission is compatible with an 02-05 Wrx clutch kit. The SS parts are slightly different sizes, meaning you shouldn't mix and match SS with wrx clutch parts. Just get a full 02-05 Wrx clutch kit.
trippywhitekid
thats what i planned on using was a full 04 wrx kit and flywheel just want to make sure im buying the correct parts. do you know if my year is a pull or push type?
The 91-94 SS trans uses a pull style clutch actuation, as does 2002-2005 Wrx. Later years of WRX went to the N/A push style.
trippywhitekid
ok. thank you for the help i appreciate it
