»  BC-BF Legacy Discussion »  Drivetrain
#will GC8 fwd CV axle work for 93 awd LGTW?
Custom Search
Login | Register
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: will GC8 fwd CV axle work for 93 awd LGTW?
PostPosted: Fri Mar 17, 2017 2:50 pm
Just picked one up and had cross referenced that the awd GC8 was the same, but think I saw a different p# for the fwd..
(cv axle going on fwd passenger side)
is there any critical difference? length? or can it still work, appreciate any feedback!
'94 Legacy Turbo Touring Wagon; kyb gr2's/mostly stock
'05 Toyota Corolla XRS - 1.8L 2zz-ge, 6speeds of revtastic fury
Profile  Offline
 Post subject: Re: will GC8 fwd CV axle work for 93 awd LGTW?
PostPosted: Fri Mar 17, 2017 5:14 pm
The fwd Impreza and legacy axles were beefier than AWD models. I can confirm the fwd legacy axles fit, haven't tried the impreza ones.
Profile  Offline
PostPosted: Mon Mar 20, 2017 8:57 pm
cool. might try to tackle this on my own soon as I have some free time, hopefully. will try to report back, maybe snap some pics
Profile  Offline
PostPosted: Mon Apr 03, 2017 6:58 pm
update on this, the fwd CV axle from GC8 impreza did in fit up, no problem. at least in my case
However, its possible this was in fact a GC8 awd axle.. kind of an unknown as seller just had it sitting around unused. so not making an claims for certain here.
Profile  Offline
PostPosted: Tue Apr 04, 2017 4:57 am
They are physically larger, both the shaft and the cups, you'd definitely notice.. Over the years, I'm sure many a thrifty owner swapped in the AWD to replace busted FWD's. Either way, a good axle beats a broken axle any day!
Profile  Offline
Who is online
Users browsing this forum: No registered users and 3 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
