Searched for a bit but wondering which shift I should use
94 turbo wagon.
04 wrk rear diff
05 lgt 5mt
I thought the 05 lgt manual would work but the bolt holes won't match at the rear diff. Length seems good though. Not 100% sure the driveshaft is from the 05 lgt manual
Thanks in advance.
I'll continue with the searching. I know I've seen it
Drive shaft help
Drive shaft help
94 tleggy wagon, 22t with 2.5 dohc heads, pp6, tdo4, fmic, 3inch catless bpm turbo back, wrx brakes, MANY interior mods to list
Re: Drive shaft help
What you gotta do is swap the flange from your old diff to the new one. As far as I know you have to use the 1st gen drive shaft, because different body styles have different lengths.
Um. Well that's gonna be an issue. Lol
Since you swapped in a manual, you need to use a manual 1st gen drive shaft as well.
Oh that's been done long time ago. Like two transmissions ago.
I have another drive shaft with the correct flange. I'm just gonna order another ujoint and swap flanges
Sounds like that should work.
