»  BC-BF Legacy Discussion »  Drivetrain
#Best choice for front wheel bearings
Custom Search
Login | Register
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: Best choice for front wheel bearings
PostPosted: Sat May 20, 2017 12:40 am
Its been barely a year and I'm going to have to replace front wheel bearings....again. I only want to do this once. What's the best choice for this?
Profile  Offline
 Post subject: Re: Best choice for front wheel bearings
PostPosted: Mon May 22, 2017 6:01 pm
From what I've heard the main issue with the bearings is not necessarily the bearing but how they're installed. Do you add grease, do you not add grease, etc. I don't know all the details, but know it's a contested issue.
In general I like the Japan-made bearings like NSK.
1997 Impreza OBS
Profile  Offline
PostPosted: Mon May 22, 2017 8:23 pm
Thanks josh, picked up fwb at dealer today. 65 bucks roughly. Did not buy hub there, that was 150 for Subie brand part. Wonder how much of a press is needed to press bearing into place. Any idea?
Profile  Offline
PostPosted: Tue May 23, 2017 5:31 pm
I'm not sure about the press. I've never done it myself. Hopefully someone else can chime in.
1997 Impreza OBS
Profile  Offline
PostPosted: Wed May 24, 2017 6:12 am
I just did front wheel bearings on my wife's Outback, I have a 20-ton hydraulic press. Wouldn't want to do it with much smaller. Felt like it took a good 10-15 tons to press the old bearing shell out.
2005 Legacy GT Limited Wagon 5-Speed. Stock-ish ;)
Profile  Offline
PostPosted: Wed May 24, 2017 7:48 pm
I change these all the time for many different subaru models. I use 20 ton press too. I use grease to install the new parts together. The most reliable brands are skf, nsk, fag
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
Profile  Offline
Who is online
Users browsing this forum: No registered users and 3 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
