»  BC-BF Legacy Discussion »  Drivetrain
#What clutch/ flywheel combination do I need??
Custom Search
Login | Register
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: What clutch/ flywheel combination do I need??
PostPosted: Thu Oct 12, 2017 10:31 pm
I have a 93 auto twag that I am getting ready to do a forester 5 spd swap on. I've done 5 spd swaps before but never a forester trans. The only question I have is what flywheel/ clutch combination do I need. Do I match it to the engine or to the transmission side?
Profile  Offline
 Post subject: Re: What clutch/ flywheel combination do I need??
PostPosted: Fri Oct 13, 2017 2:05 am
Needs to match the transmission.
Profile  Offline
PostPosted: Sat Oct 14, 2017 8:22 am
Yep, what Mike said.
There are two types of clutches, push or pull type. It's the direction in which the slave cylinder engages the clutch fork.
So get a clutch and pressure plate to match the transmission.
Had more Legacy's than I know what to with...
Current: 92' SS
Profile  Offline
PostPosted: Sun Oct 22, 2017 12:40 am
I picked up a transmission and the guy said he got it out of a 93 legacy. I looked up the code 3v- ty752va2aa and it checks out as 4.11 gears from a 90-94 legacy. My question is what legacys had 4.11 gears so I can get the right rear diff. I thought only alpine sports had the 4.11 gears and all the others ones were 3.90. Or can I use any other 4.11 rear diff out of a forester?
Profile  Offline
PostPosted: Sun Oct 22, 2017 6:07 am
viewtopic.php?t=32148
1990-1994 USDM Legacy, manual trans, non turbo awd, are all 4.11
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
