»  BC-BF Legacy Discussion »  Drivetrain
#Short shifters for 1992 JDM Subaru Legacy GT wagon?
Custom Search
Login | Register
Post new topic Reply to topic  [ 8 posts ]
Author Message
 Post subject: Short shifters for 1992 JDM Subaru Legacy GT wagon?
PostPosted: Fri Nov 17, 2017 2:23 am
Hey guys, yes I've looked on other threads for this answer, but I cant seem to find anyone with a 1st gen. Legacy GT. I'm looking for a short shifter for my car. People have said to get the stock WRX or STi shifter, but I got an after market shifter that should fit an 04 WRX and the knuckle was too small. Anybody have any advice?
EDIT: 1st gen Legacy GT
EDIT 2: Found this shifter that I think will work, but the hole that connects the shifter to the rod leading to the transmission looks way too big for the bolt that's on the stock shifter.
http://www.jayracing.com/index.php?main ... 3WEALw_wcB
JimBo
Profile  Offline
 Post subject: Re: Short shifters for 1992 JDM Subaru Legacy GT wagon?
PostPosted: Fri Nov 17, 2017 6:46 am
Won't fit. The only thing that's going to work without changing parts, is a short shifter that is listed for a pre-1995 or pre 1996-impreza. If it's listed for 1993/4/5/6-2001, the company doesn't know what they are talking about, and it won't fit.
I did it the hard way, and changed out the shift knuckle to the new style, and put in a new style shift linkage. And added a kartboy short shift and their hardened bushings. No comparison in shift quality, the new parts are *significantly* better, and I attribute much of that to the new knuckle and hardened bushings.
Knuckle:
Shift linkage comparison. I grabbed a new style linkage from a junkyard car. Should be findable on a 97+ impreza or 2nd gen or newer legacy:
and kartboy bushings. This setup will work with pretty much all the 2nd gen impreza short shifters you can find.
Profile  Offline
PostPosted: Fri Nov 17, 2017 8:11 pm
Winestone Cowboy
Or just take the stock shifter rod out and cut the welded on bracket off and move it up about 20mm like I did lol might not be the"correct" way but I'm cheap and it worked
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
Profile  Offline
PostPosted: Fri Nov 17, 2017 9:19 pm
Bruh. Those look like my pictures. Lol get yourself a newer shift linkage and swap it out like Mike says. I did this as well. Used a kartboy Wrx shortshifter that fit the new linkage. All new bushings including that joint coupler part above. Feels awesome.
Profile  Offline
PostPosted: Sat Nov 18, 2017 12:51 am
Vendor
Vendor
Yeah the best option is the track down a complete linkage for a newer model that is compatible with the commonly available short shifters. Plus get a new u-joint/knuckle or at least replace the bushings. 06-07 impreza/wrx would be ideal because the u-joint comes apart and TIC makes bushings for it.
peter@functionauto.com
Profile  Offline
PostPosted: Sat Nov 18, 2017 2:14 am
So any year model with that style setup should work for the car?
JimBo
Profile  Offline
PostPosted: Sat Nov 18, 2017 7:13 am
Yes, 2nd and 3rd gen legacy, 2nd gen Impreza models.
Profile  Offline
PostPosted: Wed Nov 22, 2017 5:29 pm
Thanks my man!
JimBo
Profile  Offline
Who is online
Users browsing this forum: No registered users and 4 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
