Cars been sitting for a while... Clutch won't release
Posted: Sat Dec 09, 2017 9:23 pm
My 92 ss has been sitting for about 6 months without being moved. Just went outside to move it and it will not go into any gear. The fluid is full, the pedal is firm (like it was before it was parked) and it returns just fine. With the engine off, I can get the trans to shift into ant gear, so I don't think its a shift fork issue.
Has anyone had this problem before? I think the clutch plate is just fused to the flywheel or the pressure plate is not disengaging.
Any advice to break it loose? I don't have the means to take the trans out to inspect it.
Thank you in advance
