»  BC-BF Legacy Discussion »  Wheels, Tires and Brakes
#Minimum offset for wrx 4/2 pot brakes?
Custom Search
Login | Register
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: Minimum offset for wrx 4/2 pot brakes?
PostPosted: Tue Aug 01, 2017 6:40 pm
Thinking about getting different wheels, but I'd like to know the minimum offset recommended so I don't get the wrong ones. Tried searching, found nothing.
Trying to go with 17x9.5
Profile  Offline
 Post subject: Re: Minimum offset for wrx 4/2 pot brakes?
PostPosted: Fri Aug 18, 2017 11:19 pm
Vendor
Vendor
It's pretty unlikely a wheel that big wouldn't clear. The rally wheels designed to fit are like 15x7 and +53 offset. At the same time, a multi-piece wheel with a really flat face could have clearance issues no matter how big/wide it is.
If you were to set your car as an 06-07 wrx, or even 04 sti, or search for those cars using the wheels you're looking for on nasioc, that would be pretty good confirmation they fit.
peter@functionauto.com
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
