195/65/15 on front 205/60/15 on rear
How is my center diff handling the small difference in tire size?
Andy Rose
1993 Subaru Legacy Sport Sedan
2003 Subaru Impreza WRX
2004 Subaru Impreza WRX STI
1999 Hyundai Accent
1999 Hyundai Accent
7mm or larger circumference difference, way out of specified limits. If you have driven for very long like this Id expect your center differential to be very weak. Already its only an 8kg unit with tons of mileage, its probably dead.
Put your car on jack stands and use the parking brake while in gear to see how easy it is to stop the rears.
What made you do this in the first place? At least move the two larger tires to the same side of the vehicle!
I busted my two front tires last weekend and needed to get back on the road. I couldn't find 2 used 205-60-15, and didn't want to buy new ones.
Won't it mess up the front diff if I have two different sizes on the front.
Andy Rose
1999 Hyundai Accent
1999 Hyundai Accent
Yes, to your car it would just seem like you're mostly travelling in a circle rather than straight.
I thought the limited slip in the front tried to make both front wheels spin at the same time. If the right and left tires are different sizes, won't this be hurting the diff.
I really don't see how the slightly smaller tires on the back is hurting my center diff all that much. I have full tread on the 205's and the 195's are almost bald. The guy at the tire place said they are the same size and when I looked up the difference on the net, I found that they are about 7mm bigger than the 205's that I had on the car.
I figured that the center diff would think that the back tires are having slight traction problems and do whatever it normally does when this happens. Is this difference in tire diamater causing it to overheat, or what really is happening?
Andy Rose
1999 Hyundai Accent
1999 Hyundai Accent
Arent 195/65R15's and 205/60R15's virtually identical in overall diameter. Just that the 205's in the rear are 10 millimeters wider. I don't think its hurting anything as long as the diameter of front and rear tires are the same, in this case they are. Heh, are you goin for the dragster/ musclecar look with the fatties in the rear?
Mark,
Mark,
I don't think the naked eye can tell a difference, but the 195's are about 7mm bigger in diameter. I would guess with the loss of tread in the front and full tread in the rear, they are about 4 or 5mm bigger. I have to drive on them until I get my summer tires in, so I hope it doesn't cause too much damage.
Andy Rose
1999 Hyundai Accent
1999 Hyundai Accent
PUT THEM ON THE SAME SIDE
The differential has a fluid. You are constantly shearing that fluid between the plates. It will wear down. Its not a servicable unit so you will need a replacement eventually.
Lets say the 205s are 635mm and the 195s are 640mm. If you put one 635mm and one 640mm on the front differential the sum is 1275. Do the same on the rear and the speeds between the two are EQUAL, meaning your center diff works like normal.
Now the way you have it is two 635 on the front for 1270 and two 640 on the rear for 1280, meaning your center differential is constant being worn. PLUS your rear wheels are always pushing the car, causing odd loading on the car that could effect handling.
You could even put on 205 on the front left and one 205 on the rear right to save the differential.
"The guy at the tire place said they are the same size"
Ohh, he must know more than we do since he works on cars every day
Do you have ABS?
Do you have ABS?
Consider yourself lucky that you don't have a rear lsd. Then you'd need THREE tires of the same size!! I had that problem this winter when I busted up one of my winter wheels.
The STi guys are just plain fuxored in this situation
"Four new tires, please."
Three of the same size and one a different size would never be permissible on an AWD Subaru.
With a rear and center LSD and an open front diff, you have to have two identical diameter rear tires and have the front tires average out to the same diameter as the rears.
Well, the rear left and rear right tires have to be the same speed so they don't upset the rear LSD, right?
And the front and rear axles have to be the same speed so they don't upset the center LSD...
The rear axle will be moving at a speed dependent on the rear tires. The front axle has to move this same speed. So, the front tires have to average out to the same size as the rears.
But isn't that within the 7mm allowed variation in rolling diameter?
I'm basing it off of this quote. I don't know the specified limits :
"7mm or larger diameter difference, way out of specified limits."
http://forums.s2ki.com/forums/showthrea ... genumber=1
I cant find the good thread on nabisco but I think the calculation was a max difference of 4mm?
- Spelling Nazi
The miata one isnt good, you have to be connected to the net and run java to use it. http://www.angelfire.com/rock3/duzy/tire.htm
- Spelling Nazi
Calculations
Just for fun(!) I did the math and get 634.5mm circumference for the 195s and 627 for the 205s. That 17.5mm difference translates into one extra revolution for the 205s for every 84 revolutions of the 195s, or 1576 revolutions per km for the 195s, and 1595 for the 205s, or 19 extra revolutions per km for the 205s.
Now we need some specs for the viscous diff, which I don't have. Anyone? What can it handle?
At 30km/h (20mph) the difference isn't too wacky perhaps - (happily for the math) about 600 extra revolutions per hour, 10 per minute, 0.167 per second.
At 120km/h (about 70mph) the difference seen by the diff is greater: 2400 per hour, 40 per minute, and (now we're getting to the point) 0.6 per second.
Purely subjectively, I think that more than half a revolution per second is getting into the range where the viscous fluid thickens, and so the diff is being wrenched. But maybe not. Anyone?
ACP
ACP
The person with mismatched tires needs to jack the car up and use a measuring tape to measure the tires. Three tires of the same size of different models (even the same brand) aren't going to be the same.
I feel most of you dont have experience with many Legacy. Ive looked at so many high mileage (with the intent to purchase for myself or others) to know that even the SAME tires on the car that weren't rotated are enough to damage the center differential. Especially on automatics that are rendered into FWD because the plates are so worn.
