205/70/15's on '95 Legacy
Will these fit on my '95 legacy wagon that has 14 inch stock steels 185/70 14's and stock brake calipers front and rear.
Need to know quick am looking at them later today.
Thanks and sorry I didn't do a search
95 Legacy L Wagon Silver 5speed 265K miles
95 Legacy L wagon Maroon Auto 135K miles
96 Legacy Outback Wagon Auto 215K miles
67 VW SC Pickup 35K miles
80 VW Diesel Dasher Wagon 212K miles
90 Chevy Z71 4 X 4 91K miles
90 Toyoto Camry 205K miles
The width should be fine, but don't know about the height with stock struts.
FWIW: I have 205/70/14's on my car with stock struts and i have maybe 1/4" of clearance on the rear and a little more on the front. So, I don't believe the 15's would fit.
Robert,
Rio Red 1990 L sedan 5MT at least 302000 mi. and Spruce Pearl 1996 Wagon 4EAT 245000 mi.
georryan wrote:
Don't knock him for thinking outside of the box. At least he has been creative.
15 inchers
Well, it doesn't sound like they'll work . Probably should be looking for 195's on a 15 inch outback alloy then .
And a shorter sidewall. I used to run 195/60 on the 15's and that was a good size for the car. I noticed only a little benefit going to 205/50 16s on Forester flat-blade wheels beyond the improvement in looks.
Re: 205/70/15's on '95 Legacy
I have 205/70/15R outback rims and tires on my 93 legacy and they fit. Only issue is when making a sharp u-turn you can hear them rub a bit.
93 Winestone Subaru Legacy L AWD-BROKEN
86 White Toyota 4Runner SR5 4x4
---Girls love it when I hit it sideways(It's a DRIFT thing)---
So, I just got a screaming deal on 4 185/75/14 winterforce on steel wheels. If the 205/70/15's fit, I should not have any issue than on stock suspension on our 94 L wagon ...right? Worse case I put in outback suspension?
The 205-70-15's may fit ...but depending on the tire (same tire size but different brands are a little different) may hit the lower spring perch. There is a good chance they'll rub the inner fender @ full lock...even w/the OB suspension. The OB suspension - complete tops/springs/struts - is (start edit) NOT (end edit) plug-n-play on your '94. Been there, done that.
EDIT: Sorry to all those who read this MISinformation. The '96-'99 LEGACY OB/Outback REAR suspension is NOT PLUG AND PLAY ('95 OB is not lifted).
The front struts will bolt up; the rear 'top hats' have a different bolt pattern that started in '95, so they will NOT bolt up.
Td
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
i am sorry i wasnt clear. I have the 185/75's. I was commenting on the previous post with the 205's.wtdash wrote:The 205-70-15's may fit ...but depending on the tire (same tire size but different brands are a little different) may hit the lower spring perch. There is a good chance they'll rub the inner fender @ full lock...even w/the OB suspension. The OB suspension - complete tops/springs/struts - is plug-n-play on your '94. Been there, done that.
Td
Argh...you were clear...i just didn't READ it.
Yes, they'll fit - 'overall diameter' is the main one to watch (I don't know how to format this to look like the web - from 1010tires ):
Stock Tire - 185/70R14
>Search Tires Tire 1 - 185/75R14
>Search Tires Tire 2 - 205/70R15
Section Width: 7.28 in 185 mm
Section Width: 8.07 in 205 mm
Rim Diameter: 14 in 355.6 mm
Rim Diameter: 15 in 381 mm
Rim Width Range: 5 - 6.5 in
Rim Width Range: 4.5 - 6.5 in
Rim Width Range: 5.5 - 7.5 in
Overall Diameter: 24.19 in 614.42 mm
Overall Diameter: 24.92 in 632.96 mm
Overall Diameter: 26.29 in 667.76 mm
Sidewall Height: 5.09 in 129.28 mm
Sidewall Height: 5.46 in 138.68 mm
Sidewall Height: 5.64 in 143.25 mm
Radius: 12.09 in 307.08 mm
Radius: 12.46 in 316.48 mm
Radius: 13.14 in 333.75 mm
Circumference: 75.99 in 1930.1 mm
Circumference: 78.28 in 1988.3 mm
Circumference: 82.59 in 2097.7 mm
Revs per Mile: 859.8
Revs per Mile: 834.6
Revs per Mile: 791.1
Actual Speed: 60 mph 100 km/h
Speedometer1: 58.2 mph 97.0 km/h
Speedometer1: 55.2 mph 92.0 km/h
Speedometer Difference: - Speedometer Difference: 3.019% too slow Speedometer Difference: 8.684% too slow
Diameter Difference: - Diameter Difference: 2.93% Diameter Difference: 7.99%
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
