Retainer Clip scrapes rotor
mvons
Post by mvons »
Hubby changed the rotors and disc pads. Heard scraping metal as wheel went around. Thought we had this noise before and let it go a week to see if any changes.
No change. We got tires today and the tire place said the retainer clip was scraping the pad.
background: This was the wheel that got hit and run by a St Paddy drunk driver 2yrs ago. Used wheel hub was replaced by mechanic. Legacy has ABS brakes.
If the retainer clip is scraping, how is that adjusted?
1991 2.2L Legacy L 2wd Auto 422k miles - waiting to have head gasket and trannie seal replaced.
RIP 1993 2.2L Legacy L AWD MT Sedan 280K prior abused.
1993 2.2L Legacy L AWD MT Wagon, got at 184k, rebuilding - burnt exhaust valves
Re: Retainer Clip scrapes rotor
Seems like he bent the clip when changing the pads. Replace the retainer clip, or bend it back into the correct shape.
beanis05
Post by beanis05 »
AWD_addict wrote:Seems like he bent the clip when changing the pads. Replace the retainer clip, or bend it back into the correct shape.
X2 most likely it was bent when reinstalled if it didn't do it prior to brake replacement
1990 Subaru Legacy L 89k auto to 5 speed winter daily driver
2004 Subaru WRX 80k
1988 Mazda Rx7 vert > Turbo 2 trans swap
1993 Honda Civic Vx Gutted
mvons
Post by mvons »
Hubby was able to bend the splash shield back and no scraping since. Probably bent when he took it off.
