Guys,
I am running the above mentioned set, and my tires are stripping on the outer edge...what can I do to fix this issue? with out having to change tire sizes???
Thanks for the help!!!
BatLegacy...PS the Batmobile Legacy tuned by STi thread coming this weekend!!!!!
Rota G Force 17x8 +48, and 235/45/17...TIRES are STRIPPING!!
Re: Rota G Force 17x8 +48, and 235/45/17...TIRES are STRIPPI
roll your fenders
92 turbo legacy: RWD W58 SWAP, td04, 3"tbe, mbc, fmic, wrx brakes/hubs, wrx seats, welded 4.11, fcd, drift steering wheel, Drifting Stickers
Did that already...its the fender liner thats tearing em up...what happens if I remove it? can the car stay like that?
Thanks,
BatLegacy
Thanks,
BatLegacy
i took mine out. no problems so far its been about 5k miles.
I lost my passenger side one and sucked up water through the intake. Hydrolocked engine tuned into split block overnight, BE CAREFUL.
WagonMafia
-Pure White 93 L Wagon converted to Turbo Wagon (almost complete)
-Pure White 92 SS parts car (doner) donated to friend
-91 Mazda miata drifto DD
http://photobucket.com/wagonmafia
Different suspension setup, or simple... Chnage ur tires, that's way too wide and your tires will lose tread 3 times as fast
Sent from your bathroom closet
its not the width thats your issue its how tall it is.
odds are when you turn the wheel its rubbing in the back side of the wheel well on a seam of metal and its cutting the tire just hammer it flat or run a shorter tire
Do a wicked stretch! lol throw 205s on that b!
WagonMafia
