Biggest brakes under legacy 15" phone dial wheels
flyguyeddy
Post by flyguyeddy »
Loke the title says, what can you fit behind them? Is wrx possible or prhaps wrx sized 4pots?
alexandermf
Re: Biggest brakes under legacy 15" phone dial wheels
Post by alexandermf »
No way 4 pots will fit, the 2 pots however will. The only 15" rims I currently know that will fit the bigger tuner ready brakes are certain gravel/rally rims. Such as my enkeis rcg4
Sent from my PC36100 using Tapatalk 2
I've heard that the 4-pots may fit under some rally 15" wheels, but can't confirm that.
alexandermf
Pretty much what I said... Certain gravel/rally rims and I was using my rally rims as an example
Ok, thanks!
I want some! Rally wheels, that is.
OP, the best bang for buck brakes you can rock (If you're willing to grab some cheapo 16" WRX wheels) is 03-05 WRX fronts, and 00-06 Legacy (solid disc) or 05-?? Legacy GT turbo (ventilated) rears. They fill out the wheels really nice!
oldscoobyturbo
Post by oldscoobyturbo »
I have 02 wrx front and stock rears works good but only with 16" wheels
I also have 02 wrx fitment wilwood 4 pots to install again needing the 16" wheels
Tires do most of the work for braking get some better tires not brakes
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
legacymax
Post by legacymax »
I have a set of wrx brakes under 15in 91 tleg wheels. It took some shaving of the caliper but it has been safe for the last 4 years. If you want to stay under 15s then I think your best bet is just some rs front calipers and some good pads and rotors unless you can afford rally wheels in which cause go for the 4 pots.
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
originalcyn
Post by originalcyn »
mike-tracy wrote:I want some! Rally wheels, that is.
Mike, if i were to do this swap, what parts would i need or what parts would i want to consider? Do i need a new master cylinder or anything like that? or is it just the brakes being swapped? Steel lines might be a good idea, i guess. But i'm really just trying to make a check list of things to purchase.
Kijan
1993 Legacy LS | PBM 227
Thesubielover
Post by Thesubielover »
legacymax wrote:I have a set of wrx brakes under 15in 91 tleg wheels. It took some shaving of the caliper but it has been safe for the last 4 years. If you want to stay under 15s then I think your best bet is just some rs front calipers and some good pads and rotors unless you can afford rally wheels in which cause go for the 4 pots.
pics?
If you have ABS, then you have the 1-1/16" bore MC, which is as large as Subaru makes....so you're good there. Some SS braided lines wouldn't hurt if you're doing the work.
originalcyn
ok sweet, thanks josh. So I need:
1x Front 03-05 WRX Brake set
1x Front 03-05 WRX Rotor set
1x Rear 00-06 Legacy or 05 LGT Brake Set
1x Rear 00-06 Legacy or 05 LGT Rotor Set
1x SS Braided line set (Front and Back?)
And pads i guess. And that's the whole deal? I'm not missing anything?
Kijan
Yup, that should be it. Get front and rear ss braided lines. The 02-05 wrx should all have the same brakes.
originalcyn
Awesome, thanks josh. Now to figure out what it's all worth and then wrangle all that stuff up...
Kijan
Someperson
Post by Someperson »
are the brackets required as well? only brackets I can find are on the rears
93 Winestone TW project
Someperson wrote:are the brackets required as well? only brackets I can find are on the rears
What brakes are you talking about?
93Leg-c
Post by 93Leg-c »
Legacy777 wrote:The 02-05 wrx should all have the same brakes.
Just a FYI, I believe in '03 or '04 the shape of the pads were changed. I don't know any other parts of the brake system were changed or if they are interchangeable but you may want to keep that in mind.
'94 TW
Someperson
Front wrx calipers
Yes, you need brackets in that case.
You're right....I seem to recall reading something a while, and I did a little check and it appears that part #'s change in 2003.
I have '02 calipers and Tire Rack had that as the mid-year change.
