»  BC-BF Legacy Discussion »  Wheels, Tires and Brakes
#Master cylinder ?
Custom Search
Login | Register
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Master cylinder ?
PostPosted: Fri Sep 23, 2016 6:14 pm
So are there huge differences between manual and automatic transmission applications? This is for a 93 Legacy. I see listings for 4 X4 and manual vs automatic, and abs or not.
This is a non abs non 4x4 car with automatic.
So will the manual trans one work? And what are the differences between them all? Thanks.
Profile  Offline
 Post subject: Re: Master cylinder ?
PostPosted: Fri Sep 23, 2016 6:23 pm
Winestone Cowboy
Should work, or at least I would assume it would work fine??
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
Profile  Offline
PostPosted: Sat Sep 24, 2016 2:38 am
Weird. I have a 93, and i thought that the options were abs and non abs.
Kijan
1993 Legacy LS | PBM 227
Profile  Offline
PostPosted: Mon Sep 26, 2016 6:16 pm
There is a difference between abs & non-abs, but there also can be (doesn't necessarily mean there is) a difference between manual & automatic because of the hill holder system.
https://i.sli.mg/MNbKBw.jpg
I believe this is integrated into the master cylinder on the manual trans cars. However you should be able to use the manual master cylinder on an auto car and the hill holder just wouldn't be hooked up if it's there at all.
1997 Impreza OBS
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
