Minimum offset for wrx 4/2 pot brakes?
YetiSmasher
Post by YetiSmasher »
Thinking about getting different wheels, but I'd like to know the minimum offset recommended so I don't get the wrong ones. Tried searching, found nothing.
Trying to go with 17x9.5
jamal
Vendor
Vendor
Re: Minimum offset for wrx 4/2 pot brakes?
Post by jamal »
It's pretty unlikely a wheel that big wouldn't clear. The rally wheels designed to fit are like 15x7 and +53 offset. At the same time, a multi-piece wheel with a really flat face could have clearance issues no matter how big/wide it is.
If you were to set your car as an 06-07 wrx, or even 04 sti, or search for those cars using the wheels you're looking for on nasioc, that would be pretty good confirmation they fit.
peter@functionauto.com
