ABS delete...also hill holder.
Tatsturbo
Post by Tatsturbo »
So I went the route of deleting my abs. Used a 93 impreza non abs with the hill holder...saw no reason to keep this option but it acts as a splitter for the lines...so there's 3 lines that connect to nothing right now.
My question is: should I just T them all together or??? I've got a pic but don't know how to post it.
Thank you.
Tatsturbo
Re: ABS delete...also hill holder.
Post by Tatsturbo »
Worth mentioning I've swapped to a 4 port svx master.
If you can find/use non-abs lines from an automatic I think that will be a better solution, especially if you're using a 4-port SVX MC.
