Big brake swap w/ new coated calipers & drilled rotors, $200
85hpp
Post by 85hpp » Wed Mar 13, 2019 3:02 am
Yesssiirrrrr... and it's good 8)
This is the Powerstop pads/rotors/caliper kit offered by RockAuto as it comes for a 2002 legacy.
Pete - '94 Legacy 2wd/auto - Mobile nightclub in progress
- '02 Legacy Outback Sedan Limited - heated leather seats, sunroof, shiny paint, cherry condition - all things new to me :)
- 2006 Honda Reflex 250cc
Re: Big brake swap w/ new coated calipers & drilled rotors,
Post by mike-tracy » Wed Mar 13, 2019 7:45 pm
Is this a review? Or a for sale post? If so, I can move it
Josh Colombo wrote:
Mon Jan 14, 2002 10:23 am
Wait....I'm confused now.
85hpp
Post by 85hpp » Wed Mar 13, 2019 9:15 pm
I recon it's a review / parts tip post? $200 is what it cost from RockAuto, I just thought the part source and application ID might be handy for some, and the price tag & pics be motivating. I'd sure have jumped on it sooner if I'd known it could be done for $200 :D
Post by mike-tracy » Wed Mar 13, 2019 9:50 pm
Ahh I got you. I did these and the h6 rears on the current SS, can't beat it
91Legacyresto
Post by 91Legacyresto » Wed Apr 24, 2019 4:35 pm
How well did these do for you? I've been looking at buying the power stop brake kit for an 02 wrx front and rear, with rotors pads and newly built calipers. Just kinda exploring the options before I buy anything. Was thinking about maybe grabbing a set of 4/2 from an 06/7 wrx but have heard it's not really worth it?
Sent from my SM-G960U using Tapatalk
91 LS Turbo Project
Post by mike-tracy » Wed Apr 24, 2019 5:06 pm
The 06/07 WRX calipers are 100% worth it for looks, plus they keep the brake balance basically the same, and you have good pad choices. For daily driving the stock brakes are sufficient. I've done both the 03-05 WRX fronts/h6 rears (and at one point 05 Legacy GT rears) and the 06 WRX fronts/rears on the same car, and the 06/07 brakes (IMO) have a much better pedal feel. But... Bang for buck, the 03-05 WRX/H6 rears win hands down.
91Legacyresto
Post by 91Legacyresto » Wed Apr 24, 2019 8:42 pm
mike-tracy wrote:The 06/07 WRX calipers are 100% worth it for looks, plus they keep the brake balance basically the same, and you have good pad choices. For daily driving the stock brakes are sufficient. I've done both the 03-05 WRX fronts/h6 rears (and at one point 05 Legacy GT rears) and the 06 WRX fronts/rears on the same car, and the 06/07 brakes (IMO) have a much better pedal feel. But... Bang for buck, the 03-05 WRX/H6 rears win hands down.
When you say H6 rears which year or model are the rears specifically? I'm a little confused cause I know there are multiple models with an H6. For what you described the 02-05 wrx fronts and H6 rears is what I'm headed for...
91 LS Turbo Project
Post by mike-tracy » Wed Apr 24, 2019 10:39 pm
All 3rd gen legacy's had "H6" rear brakes. So any 00-04 Legacy will work. If you are buying refurbished calipers, the 05-08 Legacy GT has rear ventilated discs, the same discs as the 06/07 WRX. Same diameter as the "H6" brakes, but they are a bit wider.
91Legacyresto
Post by 91Legacyresto » Thu Apr 25, 2019 12:09 am
Okay. Thanks for clearing that up for me. I tried looking around but theres quite a bit of info out there which gets confusing after reading for a while.
91 LS Turbo Project
Post by mike-tracy » Fri Apr 26, 2019 6:51 am
no problem!
