How thin it can fits on?
ej22t
Post by ej22t »
I have a set of stock 15" Legacy turbo wheele and now wants to put a set of new winter tires on.
I would like to put a thinner tires for snow tires, How thin can I put it in?
The stock size is 195-60-15
Can I put 185-65-15 or 175-70-15??
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
DLC
Post by DLC »
You should be able to fit either of those sizes on a 6" wheel with no problems.
Legacy Central
ej22t
Post by ej22t »
Dave thanks for your reply!
BTW the stock tire size is 195-60-15
and the snow tire I would like to put on is 185-65-15.
I found out the Kumho KW-15 in good price but the chart said this
tire only fits on 5.5J rims, since my stock rim are 6J.
Will it make any problems if I put 5.5J tires to 6J?
Ben
