»  Community »  Picture and Multimedia Gallery
#Aki's '94 BC7
Custom Search
Login | Register
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3
Author Message
 Post subject: Re: Aki's '94 BC7
PostPosted: Fri Mar 03, 2017 4:29 am
Welp, had a bit of a setback. I really should have listened to you mike, haha.
A rod let go in pretty dramatic fashion last fall:
But a new short block is in, buttoned up and now fully tuned. Went up to a 2.5L and upgraded the fuel system to accommodate the extra cubes:
A really big shout-out is in order to Russ' Garage and Boosted Performance; none of this would have been possible without their efforts and continued support!
The first RallyX event of the year was sadly a bit of a wash due to conditions and I only got to test with about 500ft. of dry track in the middle of the course.
That little taste was very promising, though 8)
Made for some great photos in any case:
Profile  Offline
PostPosted: Fri Mar 03, 2017 7:54 pm
Very nice! These shots would make for fantastic forum banner pictures!
Kijan
1993 Legacy LS | PBM 227
Profile  Offline
PostPosted: Fri Mar 03, 2017 9:43 pm
Oh no, that's just aweful. What do you think caused it?
Profile  Offline
PostPosted: Tue Mar 07, 2017 1:33 am
Thanks! I can double check with the photog if someone would like to use them in that capacity, but as long as watermarks are intact I'm sure it'd be fine!
Not 100% but probably just metal fatigue, the #3 rod went in to 6 pieces... Was sent off to be x-rayed but no word back yet on that. I think it'd have been fine with those rods if they were fresh, but with so many cycles already on them given the age, it was a bad idea to reuse.
Profile  Offline
PostPosted: Mon Apr 10, 2017 6:28 am
Photos are free to use if watermarks stay!
Profile  Offline
PostPosted: Tue Apr 18, 2017 3:58 am
v.7 JDM scoop, N/A hood, aftermarket splitter:
Seems to work, too! IATs dropped a good 25-30 degrees.
Going to throw some vinyl on it for now but will eventually spend more time blending and smoothing it before a repaint with body color.
Profile  Offline
PostPosted: Tue Apr 25, 2017 4:08 am
Finally got some dry weather for a local RallyCross event!
Profile  Offline
PostPosted: Tue Apr 25, 2017 5:53 pm
Looks fun!
1997 Impreza OBS
Profile  Offline
PostPosted: Sun Jun 04, 2017 8:55 pm
It's such a handful, now! I'm having to relearn quite a bit as so much about the car is new, but it's a great problem to have.
Profile  Offline
PostPosted: Fri Jul 21, 2017 1:25 pm
I am crazy Impressed in the build and it being put to use!! When they put the 2.5 in did they merge your harness with a STI harness??
91 Mica Ruby Legacy Sport 550 Robtune
94 White Pearl Legacy L SOLD
04 San Remo Red Impreza WRX
04 Java Black Pearl Impreza STI
94 Crimson Pearl Legacy Sport Partout
Profile  Offline
PostPosted: Tue Aug 01, 2017 3:14 am
Thanks! It's a JDM EJ205 harness and the original merged care of iWire. The JDM version was needed since the stock location of the SS ECU is on the opposite side of the cabin from the USDM WRX. I am using USDM EJ205 ECU and heads and an STi bottom end.
A few shots from the last local RallyCross event:
The Subaru Rally Team USA stopped by our event, and brought Chris Atkinson's Rallycross Car along!:
Profile  Offline
Who is online
Users browsing this forum: No registered users and 4 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
