I'm wondering this as well although my guess is he is running the WRX ECU seeing as the heads, harness and dash are all WRX.dropdfocus wrote:Devan, did you swap to the OBD-II w/ management or are you still on the stock ECU with a piggyback or some sort of stand-alone?
Very impressive dash swap. I've seen that done with older Imprezas but never with a Leg. Props. That is an awesome car.
