1992 legacy tw from Montana
legsportwag
Post by legsportwag »
I had a post on here but it was long ago, idk were it is so here is a new one.
Specs:
1992 touring wagon
5mt swap (01 foz trans 4.11)
Tdo4
Wrx tmic
3in turbo back
Ej22e block
Ej25d heads (clover heads)
Megan racing coils
Some random uni lug 17's
Stock ej22t ecu
FCD
Wrx 11.4" front brakes
Runs 15psi all day and loves it
turbo970
Re: 1992 legacy tw from Montana
Post by turbo970 »
i'm jealous
shoefean
Post by shoefean »
Nice Car!!
CFK
Post by CFK »
Very Nice :!:
Build Thread : HERE
92 SS 5MT. Project Daily
84 Jetta Coupe. Real Project
99 A4 Avant. Wife's Daily
Welcome back and clean looking TW.
legsportwag
Undergone a couple updates, roof rack delete, also scored a lgt wing in matching qsm.
wtdash
Post by wtdash »
HI,
Been thinking of doing this also:
Ej22e block
This should keep your CR @ about 8:1+. Stock NA pistons seem to hold up per others' experience.
You running the stock pink injectors? What fuel rails - EJ20G?
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
legsportwag
Its calculated at 8.6:1 on the dot.
Stock injectors, I actually built a set of 22 rails with 25 tabs welded to them, rails have mounts for 22 or 25 intake. Never caused an issue.
legsportwag
This is about 12-14 psi, with 800lbs of people and stereo in the car with me.
legsportwag
I'd reccomend everyone does the 22e/dohc combo, yields perfect cr yet 22e bottom ends and 25d heads are fairly common. Also performs better then single cam and also allows you to save the legendary closed deck bottom end our cars came with.
Only slight mods need to be done for turbo coolant and oil.. I'd build aother one in a heart beat.
MikeyMeyagi
Post by MikeyMeyagi »
im also boosting a n/a 2.2 block, i used sohc 2.5 heads though since i had a few sets. i drive it HARD and in 3 years its never given me a issue. get a robtune ecu, that will wake it up even more!
*sold*
legsportwag
One of these two is getting a 6mt here soon ;-) sedan is something I'm wrx ecu merging.. There is a thread in electrical fer sedan swap.
wtdash
Post by wtdash »
legsportwag wrote:I had a post on here but it was long ago, idk were it is so here is a new one.
Specs:
1992 touring wagon
Tdo4
Wrx tmic
3in turbo back
Ej22e block
Megan racing coils
Stock ej22t ecu
FCD
What HG?
How did U run the oil and specifically the coolant?
I know the DOHC heads have an oil supply and not too tough to run the oil drain back into the valve cover, but a good coolant source/return isn't as clear.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
MikeyMeyagi
theres a thread somewhere that gives step by step instructions on tapping the dohc heads for coolant. its really easy
*sold*
wtdash
Post by wtdash »
MikeyMeyagi wrote:theres a thread somewhere that gives step by step instructions on tapping the dohc heads for coolant. its really easy
Yeah - I followed THIS THREAD(pg. 3)...I had it done on my '90 T-wagon...by a local Subie shop....and it leaked. So, wanted to hear about other options.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
legsportwag
legsportwag
wtdash
Post by wtdash »
I just came across an old post of yours (last year) ....didn't you used to have an EJ257 under those heads? And did you ever figure out your idle issue running that combo?
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
legsportwag
Yep had a 257 under a different set of 25d heads. Not the best compression ratio though (9.3:1). Was spunky but that motor let go before I figured out the idle issue. Ended up being an issue in the engine harness but long since cured.
New engine combo (97 22e block, 97 25d heads) yeilds a much safer compression ratio (8.5:1) also the stock ecu compensates much better with stock engine cc's
