I kind of like the look of the 92 rears in that they do not have the orange in them. So, I scrounged a pair for cheap at the yard.
Trying to decide if I want to keep them.
whattya think: 92 rear clear lights or the stock 93 orange?
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
I'm a bit partial to the clears on the 92 myself.
You don't really want to put them on your 93 though do you? Then your 93 will look like a 92.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
i got 92's on my 93. and i jus got 92 edm onea red n clear with rear fogs. anyone wanna make offer on my 92 usdm pair?>
93BC"edm" 93GC 90BC R.I.P.
I have the 92 tails on my 94. Looks much better. I'm actually going to go the full-9, and remove the amber insert alltogether, and use a Silverstar turn signal bulb. That would be the best possible setup for the rear turn signals.
I'd actually love to run Silverstars at all corners. The fronts, because it looks better and the slight amber at some angles when off could be a functional advantage. The rears for reasons stated above.
Skid - Functionally, the lights are exactly the same. They both have an amber insert, but in the 93/94 lights, that insert is right up against the lens, in the 92, it is set back away from the lens so you cannot see it with the light off. The advantage comes from the light flasing Amber-Clear-Amber-Clear, instead of Bright Amber - Dim Amber - Bright Amber - Dim Amber. Just easier to see in the daytime and in sunlight.
