Bushing?
ej22t
Bushing?
Post by ej22t »
Does anyone know that where could I find STi bushing for the rear suspension like for the L-arm, rear cortrol arm bushings?
How much will it cost and will it worth for replace it?
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
206er
Post by 206er »
I, also am in the market for these bushings. I have seen energy suspension bushings, but they are money... like 30 bucks just for the sway bar endlinks. STI is probably even worse. anyone have an opinion on stock vs. poly? I dont want to spend 2 bills on new bushings. why do they charge so much? they have to be very cheap to produce.
regards,
jeremy
if you want poly bushings.....look at whiteline.
Else, don't bother replacing any.
